Technical Support la-l241p not detecting charger or charging battery
user60380
adaf
Hello, system is working (powers on, boots fine). The charging only is the problem. When system already on with battery, screen gets brighter when ac gets plugged. 3.3v is present on psid. All voltages around ISL95522 seem to be normal. The only issue i see is pin 25 (batgone) which stays low either the battery is plugged or not. Do you believe ISL95522 is dead? Battery is good (tested with nlba) Do you suggest anything? Please help if possible
